electric waterpump
Old 02-01-2009, 11:25 AM
yelw02GT
yelw02GT's Avatar
Default electric waterpump
anyone here ever instal an electric waterpump..or even a regular water pump on the 4.6? my freind tells me that i may need to remove the intake manifold for proper instal, is this true? and as far as the wiring goes for an electric waterpump, how in dept is it, pretty simple or should i have someone help me
yelw02GT is offline
Old 02-01-2009, 12:55 PM
Xemeth
Xemeth's Avatar
The intake doesn't have to come off. Just remove the pulley and take off the bolts holding it on. Coolant will come out, but just stick a drain pan under it.
As far as wiring, I've heard it's pretty simple, but haven't done it personally, so I can't give you a definate answer.
Xemeth is offline
Old 02-01-2009, 12:59 PM
98GTstang
98GTstang's Avatar
I'v replaced the water pump on my 98 before and no, the intake manifold does not need to come off. You need to remove the alternator and water pump pulley, and then you should have plenty of room.
No idea on the electrics.
98GTstang is offline
Old 02-01-2009, 01:21 PM
mustangman281
Banned
mustangman281's Avatar
It took me about 30min to install mine. Just remove the belt, remove the waterpump pulley, remove the water pump (hardly any coolant comes out) then install the new one in reverse order. Make sure you get a new gasket for it. For the wiring I grounded it with the fuel rail bolt and tapped the 12v switch source into the fuel pump signal wire in the engine bay.
mustangman281 is offline
Old 02-01-2009, 02:29 PM
mustangcat
Deputy CatDog - To Purr'tect and Explode
mustangcat's Avatar
Your friends on crack.
Install of even the electric one(that helps horsepower/MPG) doesn't even require removal of the intake manifold.
-Remove drive belt
-Remove old
-Put in electric
-Replace belt
-Wire harness
mustangcat is offline
Old 02-03-2009, 12:33 AM
Blk N Wht GT
Blk N Wht GT's Avatar
What kind of power have you guys seen going with the electric water pump? I see websites claim 10-11rwhp but you know website numbers...
Blk N Wht GT is offline
Old 02-03-2009, 12:56 AM
SVTeeshirt
SVTeeshirt's Avatar
^ im also intrested, also whats the chance of one of these failing and blowing ur car up?
SVTeeshirt is offline
Old 02-03-2009, 01:07 AM
mustangcat
mustangcat's Avatar
I'm thinking your car will stop itself long before it overheats and seizes. If you don't notice the engine temp., coolant light, and check engine lights all flashing in your face.
I haven't been to a dyno, so I can't say how much horsepower it added. It did add enough for a bit of a "kick." Kind of like when you turn off your A/C.
I did notice my engine running cooler around town, and a few extra miles out of each tank of gas.
Old 02-03-2009, 01:12 AM
Blk N Wht GT
So how much hp would the butt dyno say you got?
Old 02-03-2009, 09:03 AM
OzzDOA
OzzDOA's Avatar
The earlier Meziere electric pumps had problems with O rings failing, uspposedly that was fixed in the new revisions. From what I have seen you get the same HP gains from an electric WP as you get from a good set of UDPs. Around 10 hp or so.
OzzDOA is offline
Quick Reply: electric waterpump
