What will I need to bring to the shop to have gears installed?
Old 04-30-2009, 10:58 PM
asiansensation78
asiansensation78's Avatar
Default What will I need to bring to the shop to have gears installed?
Hey guys, sorry if this has been brought up already, I searched and didn't find a comprehensive list.
I have a 02 GT with 55,000 miles. I want 4.10's in it. Besides the actual ring and pinion gear, what will I need to bring to the shop to have it installed? Will I be able to use a tuner to adjust the speedo as well?
Thanks!
asiansensation78 is offline
Old 04-30-2009, 11:13 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Auto? then you need a tuner to adjust the speedo. 5spd, then you dont have to do it right away. I wouldnt give a shop any handheld...just do it yourself when you pick it up. If the shop doesnt know what bearings/seals/and fluid to use...or needs you to supply it, then find another shop. please
WhiteFoxGT is offline
Old 05-01-2009, 12:07 AM
speed_monkey
speed_monkey's Avatar
with bearings...
http://www.americanmuscle.com/rearendrebuild.html
no bearings
http://www.americanmuscle.com/moinkit8re.html
Yes a handheld tuner can correct your speedo.
speed_monkey is offline
Old 05-01-2009, 12:14 AM
asiansensation78
it's a 5 speed. how do I know if i need bearings or not? lol sorry i'm such a n00b at this
Old 05-01-2009, 02:17 AM
devongarver
devongarver's Avatar
if you have high mileage, which you dont, its a good idea to replace the bearins while its apart, save on labor and just good practice...but its really your call. I would replace em though if i were in your shoes, but thats just me and im not a mechanic so...
devongarver is offline
Old 05-01-2009, 09:14 AM
PaintballFreak
PaintballFreak's Avatar
+1 If the shop is asking you what parts are involved you need to find somewhere else lol
Just ask for a quote for parts and labor, what parts are included in that cost, then ask what the cost of just labor is if you provide the parts. I've said this before... While you might be able to get a cheaper deal buying the parts separately, often the shop will only warranty the labor when you supply the parts. That is not what you want especially with something as precise as a gear install. If they install them incorrectly, they can easily blame it on the parts you supplied.
PaintballFreak is offline
Old 05-01-2009, 09:18 AM
amoosenamedhank
amoosenamedhank's Avatar
Provide your own parts if they let you. Anything you buy from them will be marked up. Show up with everything in this link and you will be golden.
http://www.latemodelrestoration.com/...0%201&comp=LRS
amoosenamedhank is offline
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
GimpyHSHS
08-29-2015 06:30 PM
MXBT187
08-20-2015 02:36 AM
Quick Reply: What will I need to bring to the shop to have gears installed?
