Rhythmic humming that changes with speed ?
Old 05-09-2009, 05:35 PM
gjscott
gjscott's Avatar
Default Rhythmic humming that changes with speed ?
It started a couple of months ago on my 2000 GT. Sounds like it's from the front and I can feel it a little through the floor and pedals. The frequency of the hum changes with speed and gets faster as I get faster and slower when I slow down.
I've done the obvious, changed one front wheel bearing, then the other. Made no difference. Now I'm stuck
Any ideas ?
gjscott is offline
Old 05-09-2009, 05:45 PM
StockD15b
StockD15b's Avatar
maybe a wheel bearing. jack the front up, grab the tire at the 12 and 6 o clock postion and see if u can push it pull it. if so, bad bearing.
nvm didnt read all the post. hows the tires look?
StockD15b is offline
Old 05-09-2009, 06:10 PM
gjscott
gjscott's Avatar
The fronts are nearly at the wear markers.
gjscott is offline
Old 05-09-2009, 06:28 PM
PaintballFreak
PaintballFreak's Avatar
check brake pads and rotors. They make constant contact with each other and can cause noise/vibrations with warped rotors or worn pads.
PaintballFreak is offline
Old 05-09-2009, 07:08 PM
mustangman281
Banned
mustangman281's Avatar
+1 on the rotors.
mustangman281 is offline
mtgldr
02-03-2024 09:00 PM
UrS4
10-03-2015 06:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
BeatnikFink
10-01-2015 08:00 PM
musnicki
09-23-2015 07:11 AM
Quick Reply: Rhythmic humming that changes with speed ?
