Question about a MAF upgrade.
I was wondering if anyone out there upgraded their MAF to a bigger one for their supercharged GT and noticed a difference in power. I am looking at the lightnings 90mm MAF as an upgrade but is it worth the money. Right now I have a bbk 75mm TB with the stock maf which is calibrated to 30lb fuel injectors. Is it worth the switch or I will not noticed the bigger diameter size or will the bigger size help the air flow to the 75mm TB?
well are you s/c? if you are not the 80mm maf is fine with your setup with your injectors but if you are s/c the 80mmmaf is only good to around 380-400whp in which you need to upgrade to the 90mm maf and calibrate to the injectors.
I won't help at all. The stock MAF is good to around 360-370 rwhp. Mine pegged around there forcing the tuner to set my A/F mixture a little rich mid-range so that it wouldn't lean out at the top. I'm still running the stock MAF but I bought a Diablosport MAFia adapter and had the car re-tuned. With 30 lbs injectors I doubt that you will peg the stock MAF.
OP I have a slightly used set of 8 38 lb. blue injectors from Vortech with only 3,000 miles on them and I will also sell you my 90 M Lightning MAF they are on my car but I can pull them off my car, PM me if you are interested.
PS - 38 lb injectors are good for 450-460 rwhp.
$275 shipped for injectors and MAF.
jwog666
12-27-2021 08:09 PM
treesloth
09-28-2015 07:03 AM
