SO I figured out the chirping - now help me fix it!
I have a lot of junk built up in the socket and no air compressor. How should I clean it out before I remove the plug? I dont want any of that crap to fall in my head. I have 0 power loss so I doubt anything has gone really wrong yet. I guess I'll go to the store and pick up a new plug and some anti-seize
Well I went and got a 5/8" spark plug socket and a new plug just in case. After I got the cop out, I put the socket and my extension down in the hole after blowing it out with an air can. I realized I needed a longer extension to be able to get my torque wrench on it. It was obviously loose though, I could turn it with just the socket and extension in my hand. I just tightened it down with a regular socket (not too tight just slightly past hand tight). I'm going to just order a set of TR6s and replace them all next weekend. I think it will be fine until then. It just backed itself out a little bit.
There is a very good possibility that by next weekend you will be looking at needing a Time-Sert (not cheap--to do it right) or a new head (also not cheap).
Do NOT drive the car without the plug properly torqued!!!
I understand conceptually that it's not a great idea. But I've driven it for at least 2 months loose. It's hard for me to believe that now that I've tightened it, it's going to actually blow out within the next week. I drive it less than 50 miles a week.
Is it still making that chirping sound after you tightned it? If not then drive it's ***** off. 13ft lbs is just a bit past hand tight anyways. I have never used a torque wrench when installing plugs and never once had a problem.
