UPR Lower Controls remove quadshock?
Old 05-25-2009, 10:10 PM
Mustang_NTriangle
Mustang_NTriangle's Avatar
Default UPR Lower Controls remove quadshock?
I am installing UPR PRO series Moly Chrome adjustable lower control arms tomorrow. These have a billet aluminum bushings and I did not buy uppers.
My question is should I remove and throw away quad kicker shocks or keep them on if possible? Car has 55K on it.
http://www.uprproducts.com/shopping/shopexd.asp?id=2110
Mustang_NTriangle is offline
Old 05-26-2009, 01:32 AM
boss281
boss281's Avatar
i kept mine . A lot of ppl will tell u tell u to get rid of them but they dont bother me so i left them.
boss281 is offline
Old 05-26-2009, 07:27 AM
devongarver
devongarver's Avatar
do you have an aftermarket weld in sway bar? If not i would reconsider mounting those as they do not have mounts for the factory swaybar on them.
I'd leave the quads on until you do uppers.
devongarver is offline
Old 05-26-2009, 07:46 AM
Mustang_NTriangle
Really they just don't fit? Why hell didn't UPR tell me that before buying them? I will be calling them this morning.
Old 05-26-2009, 07:52 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Same thoughts as Devon re: sway bar mounts, but can lose the quads once LCA's are installed.
Your gonna get some extra noise from that rear-end, so will have to get used to it.
Jazzer
EDIT: This page was open too long prior to posting and missed above post. Agreed, call them and ask about sway bar mounts. Those arms will fit, but normally reserved for 1/4 mile guys and they don't need sway bars. Hell...... they don't even need STEERING wheels. I hear there is a good market for them on eBay, so pull them babies and save some weight gents
Jazzer The Cat is offline
Old 05-26-2009, 07:55 AM
Mustang_NTriangle
I called UPR this morning and the ones they sent me will work with factory swaybar.
Old 05-26-2009, 07:57 AM
Jazzer The Cat
Retired Moderator
Saweeet
Old 05-27-2009, 02:17 PM
03GTwhos
03GTwhos's Avatar
Hey jazzer, what noises will be heard?????
03GTwhos is offline
Old 05-27-2009, 08:15 PM
Jazzer The Cat
Retired Moderator
^ the noise, commonly referred to as NVH (Noise Vibration Harshness), is just the sound of the road in the cabin. If you put heavier springs, shocks or lower profile tires on your ride, you will have an idea.
This is really just a trade-off for a good handling ride. ALL upgraded aftermarket suspension parts are going to add some noise, but will get progressivly worse with more parts. The more poly ends the more noise. If you introduce Heim joints (spherical ends), you will get a bit more. On a nice smooth road, you will hardley notice it. BUT...... run your ride on an old rough asphalt road, turn the stereo up.
None of this is intollerable, as I run nearly 100% Heim joints on my ride with exactly 3 poly bushings and zero rubber. 30 series race tires and full coil-over suspension. It is safe to say, I have about as much NVH as any DD on this site .... I mean....
Jazzer
Gene K
10-21-2015 11:37 PM
FivePointToTheOh
09-14-2015 03:35 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Dragonus18
09-09-2015 01:21 AM
UPRSharad
09-08-2015 03:46 PM
Quick Reply: UPR Lower Controls remove quadshock?
