explosion
Old 06-22-2009, 06:38 AM
  #21
Eagle2000GT
Eagle2000GT's Avatar
If the helicoil won't fix it then I agree with you. Go to a salvage yard and find a low mileage motor. If its within your budget you might even get a low mileage 3v and get the conversion kit.
Eagle2000GT is offline
Old 06-22-2009, 06:51 AM
  #22
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Well its time to decide right now if its worth fixing the head, or just replacing the whole motor. How much $$ you're willing to spend will determine this.
http://www.timesert.com/html/triton_repair.html
Thats the cheap way out.
However considering your mileage, I'd look into finding a used low mileage motor.
WhiteFoxGT is offline
Old 06-22-2009, 07:52 AM
  #23
Ryan86272
Ryan86272's Avatar
Depends are you going to Fix the Head your Self? Install the motor by yourself?
The Price in Labor your going to Get Charged you can probably get a used motor.. And swapping motors in our cars are CAKE....
Where do you live Liljojo..... (are u a girl? isnt she a singer?)
Ryan86272 is offline
Old 06-22-2009, 08:49 AM
  #24
liljojo4711
liljojo4711's Avatar
how much is that kit for the repair? i could not do anything by myself but my moms husband knows what hes doing. this is my dd so i cannot be without a car long.
how much is the kit for a 3v conversion?
liljojo4711 is offline
Old 06-22-2009, 09:10 AM
  #25
liljojo4711
*update* i went outside and pulled the coil loose and the spark plug came right out with it lol. obviously, the threads are stripped so yall know ur stuff . if i go new engine or new heads i will need a loan from the bank because i just graduated college and dont have a job yet. job market sucks lol. so i need the cheapest quick fix. any suggestions? plus im in houston and live in dallas so i need some way to get my car home...
Old 06-22-2009, 09:55 AM
  #26
mustangman281
Banned
mustangman281's Avatar
Just helicoil/timesert it. You can buy it at autozone. It's very easy to do.
The kit comes with a drill bit, tap and helicoil. make sure both valves are closed in that cylinder. Just drill out the hole, grease up the tap and slowly tap the hole, install the helicoil, break off tab, do your best to vacuum out the cylinder install sparkplug and torque it to 13ft lbs. Don't worry if you can't get all the aluminum shavings out of the cylinder. Aluminum will leave the exhaust after the first few rotations and aluminum will not scratch the walls.
mustangman281 is offline
Old 06-22-2009, 10:21 AM
  #27
liljojo4711
so the head has to come off or not? its that easy huh...
Old 06-22-2009, 10:42 AM
  #28
reznap
reznap's Avatar
I'm stunned to learn that you can do this without removing the cylinder head. That's really incredible... good luck with your fix jojo!
reznap is offline
Old 06-22-2009, 10:55 AM
  #29
mustangman281
Banned
Your lucky it's number 2 cylinder so it's very easy to get to and you don't have to pull the head. I had to fix #4 cylinder on a lightning. I had to pull the head to get to that one and it was a bitch.
Old 06-22-2009, 11:25 AM
  #30
liljojo4711
its actually #3... which looks like a bitch to get to
Quick Reply: explosion
