Sticky Clutch.
Sticky Clutch.
Latley my clutch pedal has been sticking here and there, sometimes it will be hard to push in and sometimes it will stick after letting it out, once I actually had to put my foot under it and lift up to get it to let out. It was replaced almost exactley 2 years ago by a cheap Auto Zone clutch, it was what I could get quick I didnt have time to shop cause i needed the car. It never does it when going from neutral to first, only when shifting gear to gear, most of the time now I shift with out the clutch, but that wont work forever! Question is, is it the clutch itself or something in the cable? Any one have issues like this before? And if it is the cable and not the clutch is the install hard, like do I need to remove the tranny like replacing the clutch?
muchos gracias mi amigos!
I agree AutoZone FTL on stuff like clutches, I ordered me up a new RAM Clutch kit and a Steeda Clutch adjuster cable kit from AM. I think it is a return spring in the clutch that is the problem, either way it should be replaced being an AZ clutch, and it is long over due for the Steeda mod, even if i am not planning on keeping the car long.
ccdguy
09-19-2015 05:20 PM
