catlitic converter question.
Old 06-25-2009, 10:12 AM
ForbTheStang
ForbTheStang's Avatar
Default catlitic converter question.
i just baught my 01 GT and i drove 2 and a half hours to get it. i drove it 2 and a half hours back with no problem. well the day after my check engine light came on and i took it to autozone and they said i had a bad cat well i noticed that the floor by the pedals gets real hot and on the lower dash gets real hot also could pluged up cats cause this? i have a borla cat back and the cats were elinated could that cause my check engine light? i relly do think my front cats are bad.
ForbTheStang is offline
Old 06-25-2009, 12:23 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
I doubt your cats are bad and if it was plugged up, you would blow-up your motor.
If you installed an aftermarket X or H pipe, you have eliminated your rear cats and WILL trigger a dash light if not addressed with MIL eliminators. Was this the first drive without your rear cats?
Jazzer
Jazzer The Cat is offline
Old 06-25-2009, 12:33 PM
cbbass123
cbbass123's Avatar
from the pics it looks like somebody removed the back cats and welded in a pipe for replacement. That would probably trip out the rear O2 sensor with diff readings. Take it to a muff shop and they can tell if cat bad or not. <---Sometimes with vibrations when banging or if air in exhaust is low coming out. As for heat...check for minor exhaust leaks where welds are or where heat is at strongest. Exhaust gets boiling hot and small leaks can warm up bottom floor. What is the actual code the check engine light gave? That would help too.
cbbass123 is offline
Topless06
Topless06's Avatar
Do you smell a rotten egg smell. I believe when they getting close to being clogged they smell like this. Correct me if i am wrong
Topless06 is offline
Old 06-25-2009, 01:01 PM
ForbTheStang
the back cats are gone. i dono what the code is ill have to get it re plulled by why would the light take 5-6 hours to come on? i dont think there total pluged but i think there getting bad.the lowerdash does get relly hot its the only thing i can think of.
Old 06-25-2009, 01:52 PM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
A bad cat can cause excessive heat build up, but it does sound to me like it is more related to the modifications made to the midpipe than anything else.
ChalknCover is offline
Old 06-25-2009, 10:49 PM
ForbTheStang
what problem could the mod to the mid pipe be?
Old 06-25-2009, 11:20 PM
gunpig0313
gunpig0313's Avatar
It looks like a hack job bro I would take it to someone that know what the hell they are doing and have them fix it. If you state doesn't have emissions test just get and off road x or h mid pipe.
gunpig0313 is offline
Old 06-26-2009, 12:02 AM
ForbTheStang
im having a guy in town make me an x pipe well see how it goes.
Old 06-26-2009, 12:17 AM
gunpig0313
gunpig0313's Avatar
Dude just buy one there cheap as hell americanmuscle.com check it out.
Quick Reply: catlitic converter question.
