Crooked Lowering Job
Old 07-11-2009, 12:45 PM
mustydakota
mustydakota's Avatar
Default Crooked Lowering Job
Hey guys about 2 weeks ago i through a set of 1.5" racecraft drop coils in my 01 gt. Everything went fine but shes sitting a lil crooked right now. Seems like the back passenger side is higher than the drivers.
Could it be the spring turned on reassembly of the rear end. If i remember the pig tail on each spring is suppose to be pointing to the driver side for the rear install. If that turned a lil on reassembly would it raise the rear a bit????
any help would be awesome guys
mustydakota is offline
Old 07-11-2009, 06:55 PM
Choppa
Choppa's Avatar
ya guys always talk about the springs being seated correctly i havnet lowered ne thing yet but if the spring isnt seated correctly it could cause this problem i guessing there is a nothc where the top or bottom of the spring lines up with and it needs to be resting in this notch
hope this helps
Choppa is offline
Old 07-11-2009, 10:26 PM
HEAVYMETALMATT
HEAVYMETALMATT's Avatar
Jack the rear up and check. I put both of mine facing the back to level it out.
HEAVYMETALMATT is offline
lincolnshibuya
07-05-2020 03:05 AM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
GLOCKer
09-28-2015 07:36 AM
09-25-2015 09:06 AM
Quick Reply: Crooked Lowering Job
