whats the deal?
Old 07-13-2009, 04:36 PM
yellow40th
yellow40th's Avatar
Default whats the deal?
for my 04 gt the owners manual says 6 qts of oil....i put 6 in and it is barely past the fill line on the dipstick.....do i need another qt??
yellow40th is offline
Old 07-13-2009, 05:03 PM
yellow40th
yellow40th's Avatar
a guy i work with has an 01 and his is full with 5 1/2 qts......and he said he has a friend with one who says his takes 7 1/2 qts to fill............ this is beat, maybe il stop on the way home and get another qt
Old 07-13-2009, 05:13 PM
CAMDUP
CAMDUP's Avatar
i usually have to put 6 1/2 in my 04 in order for it to read full
CAMDUP is offline
Old 07-13-2009, 05:27 PM
Hangwire
Hangwire's Avatar
1) These heads hold alot of oil.....give it plenty of time to sit after running....which still leaves a decent amount in heads anyways.
2)These dipsticks arent the most reliable.....5-6 quarts will be fine regardless of the reading on the dipstick unless you're leaking.
Hangwire is offline
Old 07-13-2009, 05:31 PM
yellow40th
yellow40th's Avatar
yeah i just searched and see that the numbers are all over the place, im gonna stop on the way hmoe and get another qt and probably put 1/2 of it in to be safe
Old 07-13-2009, 05:47 PM
StriderTacticaL
StriderTacticaL's Avatar
+1 my 04 GT is the same way.
Theres been tons of threads about this and basically some people have determined that 6 quarts is not quite enough and running 7 quarts allows for proper circulation of oil at WOT. I just put in alittle more than 6 and I read right under full which is fine with me.
StriderTacticaL is offline
Old 07-13-2009, 05:51 PM
DreamerGT
DreamerGT's Avatar
both mine take 6qt's there good
DreamerGT is offline
Old 07-13-2009, 06:09 PM
StriderTacticaL
Oh and one more thing...this might be terribly obvious to some of you but make sure that if you are starting your car up for a while to get the oil to go through the filter and all...give it minutes to let all the oil drip down to the pan after your shut off...
Old 07-13-2009, 08:41 PM
JC316
JC316's Avatar
7-7.5 quarts for my 96 GT. That 6 quarts is a crock.
JC316 is offline
Old 07-13-2009, 11:06 PM
E714FEVER
E714FEVER's Avatar
All Modular motors take 6 quarts. Make sure your dip stick tube is all the way in the block.
E714FEVER is offline
Quick Reply: whats the deal?
