tubular k member 96 gt
Old 07-15-2009, 10:40 AM
rad400
rad400's Avatar
Default tubular k member 96 gt
I ordered a tubular k member for my son's 96 gt, and the guy at summit said something about part to aligning the car later. Do this parts need to be install with the k member for can they be put in with the other suspenion parts later? Car is down for a will until the frt end is fixed.
Thxs
rad400 is offline
Old 07-15-2009, 10:54 AM
Yellow Fever
Yellow Fever's Avatar
He probably meant caster/camber plates . They are adjustable . And should go on at the same time as the K-Member . It's alot easier doing it all at once .
Yellow Fever is offline
Old 07-15-2009, 11:21 AM
lizzyfan
Underboss
lizzyfan's Avatar
Yes, you should get your front end aligned after K member install
lizzyfan is offline
Old 07-15-2009, 11:33 AM
grogan
grogan's Avatar
u need to get caster camber plates when u do a tubular k member with coil overs, they wont fit into the stock plates. and a front end alignment is always recommended.
grogan is offline
Coyote_hpr
11-12-2019 12:44 PM
rgingo
Forum Issues and Feedback
10-21-2015 12:49 PM
Dokilar
15
10-16-2015 08:13 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Quick Reply: tubular k member 96 gt
