Car is leaking anti-freeze on backside of the engine - need input
Old 07-23-2009, 11:26 AM
rollintechno
rollintechno's Avatar
Question Car is leaking anti-freeze on backside of the engine - need input
Hey guys, my '01 stang with a lil over 65k is leaking anti-freeze. Without putting on a lift I can not tell where it is coming from.
From what I can see, if you're looking over the engine from the drivers side fender on the right side of the valve cover there is a narrow gap between the end of the valve cover and the firewall, which I can't quite see down through cuz of the lack of space.
But I notice fluid dripping from what looks like right under the far right part of the valve cover. It actually drips on to the rear part of the exhaust header. When it hits the ground, it's landing right @ the door hinge, almost in the middle of the car towards the drivers side.
It's leaking quite a bit of fluid, too.
Any guesses @ what it could be? Heater core pipe maybe? Or what it would take (time & $$$) to fix it? I doubt I will/could do this job myself.
Any input is appreciated. Thanks
rollintechno is offline
Old 07-23-2009, 11:55 AM
BOSTANG
BOSTANG's Avatar
Sound like the intake.
BOSTANG is offline
Old 07-23-2009, 12:57 PM
jivepepper
jivepepper's Avatar
It's probably the heater core hoses that go from the intake and water pump to the heater core or a cracked intake.
jivepepper is offline
Old 07-23-2009, 01:24 PM
JC316
JC316's Avatar
Could be a freeze plug in the head, or more than likely, it's one of the heater hoses.
JC316 is offline
Old 07-23-2009, 01:48 PM
PaintballFreak
PaintballFreak's Avatar
Had this exact leak. Turned out to be a manifold gasket, not the manifold itself. Good luck though - could be any one of the things previously mentioned as well.
PaintballFreak is offline
Old 07-28-2009, 08:38 AM
rollintechno
Thx guys. I will let ya know what I find out when I get it shopped.
Old 07-28-2009, 12:21 PM
04CompetitionOrange
04CompetitionOrange's Avatar
Shop diagnosed my old coolant leak coming from the manifold gasket too...it wasn't until we pulled the intake that we found the crack in the manifold itself. Good luck with the repair.
04CompetitionOrange is offline
Old 07-28-2009, 01:25 PM
fausty
fausty's Avatar
More than like the infamous intake took a dump on you. If you need to purchase one pm me I have a brand new one.
fausty is offline
Old 07-28-2009, 01:48 PM
Repzard
Repzard's Avatar
Bingo !! Thats my guess too.
Had the same problem and thought the intake was cracked like their famous for.
Nope it was just a intake gasket, but in a way im glad I replaced intake with new design, dont have to worry about cracks and its a life time warranty .
It was a simple job to replace poster if thats your case.
Good Luck
Repzard is offline
Old 07-28-2009, 02:11 PM
rollintechno
Good Luck
What is the time invested for a job like that? I feel this may be beyond my skillset. Any special tools or methods required?
Quick Reply: Car is leaking anti-freeze on backside of the engine - need input
