blown engine
Old 08-07-2009, 01:02 PM
liljojo4711
liljojo4711's Avatar
Default blown engine
my car has 192,000 miles and im wondering what causes an engine to just stop working? what are the most common reasons people have to replace their engines? im asking because im thinking about just reusing my block when my engine stops working eventually. is there anything that would prevent me from being able to reuse it? i would probably just get an all forged rotating assembly kit when this happens. what other things should i do to the block itself?
liljojo4711 is offline
Old 08-07-2009, 01:33 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
When an engine goes its usually not the block that fails, but a rod bearing or piston/ring.
Most of the time the block is re-used during a rebuild. Blocks dont wear out... its when the components inside fail and damage the cylinder walls or crack something.
WhiteFoxGT is offline
Old 08-07-2009, 02:32 PM
liljojo4711
so what should be done to the block, given it is reusable, before i start throwing a new rotating assembly in there
Old 08-07-2009, 02:55 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Clean, check for cracks, bored .020 over, honed
Old 08-07-2009, 03:21 PM
dimebag
dimebag's Avatar
That and... Check the main journals, posibly hone them. New oil plugs and freeze plugs, I'd surface the block aswell
dimebag is offline
Old 08-07-2009, 03:36 PM
liljojo4711
yall have a rough estimate of how much all that will cost
Old 08-07-2009, 03:54 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Whatever your machine shop labor rate is plus material
Old 08-07-2009, 05:35 PM
liljojo4711
material for what
Old 08-07-2009, 05:38 PM
Hangwire
Hangwire's Avatar
Also.....how much will the stock blocks hold? If you're throwing a fully forged rotating assembly in there then that means you plan to put down serious power.....will this block handle that power?
Materials=Rotating assembly/plugs/whatever they need to bore it over.
Hangwire is offline
Old 08-07-2009, 05:54 PM
liljojo4711
oh ok cool. i plan on no more than 450hp.
Quick Reply: blown engine
