new intake manifold
Old 08-20-2009, 03:24 PM
sleeping stallion
sleeping stallion's Avatar
Default new intake manifold
hi i just purchased the edelborck efi manilfold and had a question has anyone have any experience with it. my car is a strip car not the fastest but it went 11.6 at 122 1.78 60 foots with just ported heads and stage 3 comp cams 100 shot long tubes and intake. so i went with this new intake and got all new suspension lake wood 90/10 up front 50/50 rear with steeda upper adjustable control arms and steeda lower control arm. can anyone give me any more info or if anyone would change anything in my set up let me no pls thanks
sleeping stallion is offline
Old 08-20-2009, 06:26 PM
dimebag
dimebag's Avatar
What gear is in it? 4.10s are the way to go for you.
That intake will like rpm, which again is a good thing.
Do what ur doing, and use some decent upers and lowers, and a good tire, you should be capable of low 1.6 or even high 1.5 60fts
Should do 11.4s or so
dimebag is offline
Old 08-20-2009, 08:31 PM
sleeping stallion
I have 373 and a stock auto. You think i can get better 60 foots wow i hope. I going with the 90 or 95mm elbow and dont no what tb yet. Like i mention i have ported heads. The shop said they are considered race port so not sure what stage or specs they have. Since shocks and struts are lake wood what uppers and lower you think i should look at. Or should i ditch those lakewood
Old 08-21-2009, 12:45 AM
dimebag
dimebag's Avatar
Lakewood is great, I and many others run them. Look into baseline control arms, I plan on running them in the future
Didn't know u had an auto. No you won't cut those times with it as of now. Get 4.10s, and put some money into that trans
dimebag is offline
Old 08-21-2009, 05:53 AM
uberstang1
Chupacabra
uberstang1's Avatar
I would pick up a pair of subframe connectors and a torque box kit from UPR
uberstang1 is offline
Old 08-21-2009, 09:56 AM
sleeping stallion
Ya ill look into that has anyone seen any good results with this intake i no the runners are short
Old 08-21-2009, 10:08 AM
Sxynerd
Sxynerd's Avatar
My intake pulls great and it doesn't feel like I lost any power down low. And just because it has a high end power range doesn't mean it's just an up-top intake.
Sxynerd is offline
Old 08-21-2009, 10:51 AM
sleeping stallion
So you have the same intake what elbow tb and intake you use if you dont mind me asking do you like it over the stock or typhon
Old 08-21-2009, 01:40 PM
Sxynerd
Sxynerd's Avatar
Of course I like it better than stock and the typhoon. The typhoon is a stock design made out of aluminum. The Edelbrock intake is the best cast intake with the most DIRECT flowing intake path.
If you're NA and are completely stock, work on the other mods first.
Sxynerd is offline
Old 08-21-2009, 02:26 PM
sleeping stallion
Coo thanks man i have full bolts on with some nitrous stage 3 cams really open the car up
mrtrodonet
09-19-2020 03:12 PM
daltron
04-28-2016 08:10 PM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: new intake manifold
