Cobra Rear Brake install
rear brake set is pretty easy just buy the kit and if you want new calipers get them also
remove wheel,rotor, caliper,bolts,caliper
caliper bracket, dust shields, moan braces
drop the diff cover,pull the c clips
pull the axle, remove the caliper bracket,and install larger one
install new moan braces
repeat the process back and you will be done
just remember to refill the diff
and bleed the brakes if you decide to swap out the calipers
hope the helps
hope the helps
Fast-Hands
08-19-2015 06:54 AM
