do i need fuel pump with 100 shot
Wait a minute...didn't this question just get asked the other day in this very part of the forum?
Anyways some people will say yes you do need a new pump because you are nearly maxing out your fuel pumps load and others will say no. I say no, you don't need a new pump but it isn't a bad idea to get one to be on the very safe side.
But I guess I didn't answer your question. The answer is yes you need a fuel pump to run nitrous, or the car at that ha ha ha
Dont worry about it, especially if you have a wet kit the fuel that sprays through the nozzle will be calibrated to a specific amount along with the nitrous. Your safe. Spend money on a window swtich, or just get a wot switch and risk it. youll be ok.
i ran my stock 4.6 with the factory pump for about 3 months until i found out i was getting to a very unsafe lean point in in the top of third(my car is an auto so it would be top of 4th for a 5spd). put a focus pump in and never had a issue again till the i got cocky anf grenaded the motor with a 150 shot. jusy absoultly under no reason hit the kit in overdrive in an auto or 5th in a 5spd. It will go lean and most likly pop number 4 or 8 cyl.
yeah thats what i changed to then now with the 5.1, heads, cams, intake, and lts ive got 03 cobra setup
