Rearend shifted to right
Old 09-14-2009, 08:00 PM
fisher2985
fisher2985's Avatar
noticed mine looks the same (to the right) after i put the 9 inch wheels and 1.5 inch spacers on. i dont think uve got anything wrong, just most are like that with wide wheels on. before the spacers i never noticed mine.
fisher2985 is offline
Old 09-14-2009, 08:21 PM
reznap
reznap's Avatar
It's one of those 'mustang things.' I've heard about this, and some cars also lean (one side sitting lower than the other). I'd tear the LCA's and UCA's out and throw in some new poly bushings. This way you can inspect the parts better while they're on a bench.
reznap is offline
Old 09-14-2009, 10:23 PM
01GTDropTop
01GTDropTop's Avatar
Sonafab*(^%$, I knew it! I knew my car always leaned to the right (pass side). Like the owner before me had his fat a$$ wife in the car for the first 44,XXX miles of the car's life. For shame, even it out, let her drive once and awhile; give it that lowered look.
I need to fix this, it's driving me NUTS!
01GTDropTop is offline
Old 09-14-2009, 11:23 PM
gunpig0313
gunpig0313's Avatar
Mine does the same thing. It bugs the $#it out of me to look at the car and see it lean to the right. I never noticed it tell I put the 10.5's on the rear.
gunpig0313 is offline
Old 09-15-2009, 03:39 AM
trgibson1
trgibson1's Avatar
Glad to know it's not just me!!!! Thought my car was all jacked up for some reason. Nature of the beast.
trgibson1 is offline
Old 09-15-2009, 06:55 AM
Vovovovan
Vovovovan's Avatar
a friend of mine was doing donuts and bent control arms so when he puts 315's you can see that one wheel sticks out more
Vovovovan is offline
Old 09-15-2009, 07:42 AM
devongarver
devongarver's Avatar
This is something that be easily be fixed with adjustable control arms. Putting a single wheel spacer on one side or the other is not going to solve the problem. Baseline has a rear end locator bracket for 60$ that is used in conjuction with their upper CA set up.
devongarver is offline
Old 09-16-2009, 05:09 PM
trgibson1
trgibson1's Avatar
Cool, I'll look into the rear end locator bracket and the control arms. That bracket set up actually sounds like a good idea anyway. Would probably prevent future problems as well.
Old 09-16-2009, 05:27 PM
Sxynerd
Sxynerd's Avatar
Most solid axle cars are built that way guys. I've had built/owned 15 cars in my life and everyone of them have been kicked out to the passenger side by some amount. 67Elcy, 72nova, 71 Stang, 86 Monte SS etc etc. IDK why but they just are. Still check for clearence issue and of course the obvious issues in case of damage.
Sxynerd is offline
Old 09-17-2009, 07:33 AM
devongarver
here is the upper CA setup, and here is the track locator. There is alot of good info on this website, Kevin is on Vacation right now, but he will answer your questions when he returns!
Quick Reply: Rearend shifted to right
