Question for supercharged owners
Right, some of you know my car, but just to recap:
06 GT, 12,500 miles from new, STOCK clutch, had Whipple HO on from around 4,000 mile mark. Makes around 450RWHP
I don't drag race it, NEVER power shift and although I have taken it on road course track days, I'm very easy on the clutch, ie, in or out, not dragging it etc.
The question: I know it's not something you want to do normally but somebody must have done it - Can you induce clutch slip in 4th/5th gear?
Today I was out on a back road on the way home and during a WOT run in third gear she broke traction slightly on the slightly dusty asphalt, I guess it was at around 75mph, so no sweat, I merely grabbed 4th and kept on it, I definately felt/saw some small slippage.
Of course that bugged me incredibly so I had to try it again, and sure enough I can coax slippage in 4th. Depending at what RPM/throttle I engage the clutch, I can actually get the clutch to lose the motor versus clutch battle.
Now I've got to be hitting it hard to do that but really, is that something I should expect with 455rwhp+ and a stock clutch? I have felt it before, on the way to the road course of all times/places, but she ran fine on the course with no issues and that was probably 1000km's ago.
The other thing could be that the slave cylinder isn't fully releasing, i notice the bite point is much higher of late... Is there an easy place i can easily crack the line for a split second to release any hydraulic pressure which might be still in the slave ??
The 5th gear slip is the reccomended way to test your clutch though i can't see it going bad @ only 12k miles, your powerlevel might have something to do with that. Also i think you have a hydraulic clutch, were still all on cables.(this is the 96-04 section) there is a section dedicated to s197s.
But im sure someone here can probably help more than i can.
Edit: i see you have 2800 post i can only assume u accidently posted in the wrong section lol.
Luke9222
10-22-2015 11:55 PM
jaiidutch
09-14-2015 10:29 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
