Hahahaha.. uhh suspension help please
Old 10-01-2009, 03:06 PM
ramprat1983
ramprat1983's Avatar
Default Hahahaha.. uhh suspension help please
Well, the car wasn't squatting with the lower control arms in the location that the new brackets put it in, the car rode stiff as hell, and actually when launching the whole car felt like it lifted up and not just the front.
so i took the relocation brackets off, and put the lower control arms in the stock location, and now it squats, it gets better traction when launching but..
NOW I LOOK LIKE A REDNECK'D CAMARO!!! WTF
how the hell did that happen? the only thing i can check or attest to is, maybe the spring perch on the new lower control arms are moved more forward than the stock ones were and it's causing it to lift the rear up?
anyway i wanna correct it but still get that nice squatting / traction that i've gotten by having it up like this.. any suggestions?
ramprat1983 is offline
Old 10-01-2009, 03:09 PM
0949er
0949er's Avatar
fill that space up w/ some tire
0949er is offline
Old 10-01-2009, 04:08 PM
ramprat1983
yeah i'm gonna need some mudding tires or something, those are 275 50 15 drag radials, even with the stock 245 45 17's it's the same :|
Old 10-01-2009, 06:12 PM
dimebag
dimebag's Avatar
Lol 275 50 15 drs are 26in too, like ur stockers
Fyi... You know that squat is bad right? What it did before was actually better
dimebag is offline
Old 10-01-2009, 06:43 PM
jeff37110
jeff37110's Avatar
Its a common thing for the sn's to lift...Thats one of the ways they plant the tires to the pavement..
jeff37110 is offline
Old 10-01-2009, 07:25 PM
PaintballFreak
PaintballFreak's Avatar
You put the springs on the perches with the pigtails pointing the same direction I assume? If you got them backwards it will sit significantly higher...
PaintballFreak is offline
Old 10-01-2009, 07:52 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Looks like you torqued the LCA's when the car was still in the air. Loosen them back up and lower the car to the ground and tighten them under load of your car.
Jazzer
Jazzer The Cat is offline
Old 10-02-2009, 05:18 PM
dimebag
dimebag's Avatar
Dude, that wouldn't do it that badly... Its not that... The lcas are designed to use a drop mount, so the spring perch is moved up. Simple soultion, put the brackets back on... The lift is a good thing
dimebag is offline
Old 10-03-2009, 07:15 PM
ramprat1983
well, ran it last night with the thing jacked up after checking everything and finding nothing wrong.. well.. it obviously did something cus the *** end romped down and it took off, cutting 1.8's instead of 2.2's.. propelled me to a nice 13.684 @ 100 - need to retune the fuel so i might be even faster.
Old 10-03-2009, 08:45 PM
Mustangbrenna84
Account Closed
Mustangbrenna84's Avatar
I like it with the tail end up a little. Looks nice =) Ever thought about drag bags?
Mustangbrenna84 is offline
Quick Reply: Hahahaha.. uhh suspension help please
