RPM limitations of stock 2v
#21
The search has worked for me for a long time now.. Anywho you have a Romeo with bolt on cam gears so no worries. THe windsor motors have valve covers with 13/14 bolts
#24
#25
So i'm just curious, how are you going to do the install? Just straight up, degree you current cam gears, buy new ones, etc? Do you plan on measuring ptv clearence?
#26
There is not PTV clearance issues with stage 2 cams.. there never has been and never will be lol. There designed to be a direct drop in. 2.5 and up have the red flags.
#27
After talking to Bart he assured me that its not worth degreeing these cams. He said that they had tested a lot of cars and even tho some where 2*off the power loss was minimal(still hit 300 to the wheels). So im not going to waste my time on that.
Well, you're braver than i am lol. Good luck, and keep us posted.
#28
Shoot id rather do an OHCS on a motor in the car than a OHV swap like on a 5.0. At least the cams are on top lol. The hardest part is moving all the **** out of the way and removing the valve covers. The rest is just a torque wrench, valve spring tool and some cold beer. With the exception of taking off the timing chains and valve springs, the actual removing/putting in the new cams is easy. its like 6 bolts on each head IIRC.
Just like adding another bolt on
#29
Try squeezing one of those valve covers off on a 5.4... I definitely came up with a few new swear worlds that day.
I've never done cams with engine still in the car... but it's really not that big of a deal. If you know what side of the ratchet you're suppose to be holding, you'll be alright.
