High idle 1400rpm in neutral...
Old 01-18-2010, 08:58 AM
b96gtman
b96gtman's Avatar
Default this is how to adj the TPS
ADJUSTING THE THROTTLE POSITION SENSOR
After the new throttle body is bolted on, the final order of business is to correctly adjust the Throttle Position Sensor (TPS). Adjusting the TPS to the correct voltage is not difficult. It will require a Digital Voltmeter and a correctly sized screw driver.
The TPS is in essence, a low voltage potentiometer or resistor. It provides input data to the ECM (“the computer”) regarding the position of the throttle. Without the TPS and without the correct voltage, the computer has no idea as to where your “right foot” is, whether it is off the pedal (such as at idle) or at part throttle or at full throttle. The TPS supplies a gradually increasing supply of voltage to the ECM as the throttle is gradually opened. How the ECM processes this data depends on many prevailing conditions, including engine speed, load, vehicle speed, engine and ambient temperatures, and so on. The information from the TPS is especially critical for proper start-up and idle, as well as smooth throttle response. An incorrectly adjusted TPS may be most notable by an idle speed that is either too fast or too slow, or an engine that will not return to idle quickly after your foot is off the throttle. The proper idle speed should be between 750 and 900 RPM, and will be dependent on different engine combinations, particularly with engines that may have non-stock modifications.
To adjust the TPS, follow these instructions.
The TPS is a small black plastic device affixed to the throttle body with two screws, and located on the opposite side of the throttle cable linkage. The end of the throttle shaft has a blade that fits into the TPS. The TPS is electrically connected (with a quick disconnect plug) to the main wire harness.
After you have replaced your original throttle body with your new one, remove the TPS from the original throttle body and install it on your new Accufab throttle body. If new screws have been provided in the package from Accufab, use these screws (they are shorter). If not, reuse the original or stock screws. Reconnect the TPS to the wire harness.
You will need to adjust the TPS to get the correct voltage at idle. Changes to the idle speed can ONLY be made by adjusting the TPS. DO NOT ADJUST THE STOP SCREW ON THE THROTTLE BODY UNDER ANY CIRCUMSTANCES. This has been pre-adjusted at the factory to insure a proper “air gap” around the throttle blade in the fully closed position. If by chance this stop screw has been re-adjusted in the field (by those that adjust first and read the instructions last), it may be necessary to return it to Accufab for re-calibration. Before sending it back, call first and we may be able to give you re-calibration instructions over the phone.
The TPS is connected to the main wire harness with three separate, color-coded wires. You will see a “gray & red” wire, a “gray & white” wire, and a “brown & white” wire.
The “gray & red” wire is the ground wire (on some TPS’s it could also be a black wire).
The “gray & white” wire provides the positive voltage information to the ECM (on some TPS’s it could also be a green wire).
The “brown & white” wire provides a positive 5-volt reference signal WITH THE KEY ON (on some TPS’s it could also be an orange wire).
If you have any problem identifying the different colors or if the wires are different colors from those described, check inside the plastic quick disconnect plug. The plug connection tangs should have an “A”, “B”, and “C” next to each tang. “A” is the “gray & red” wire, “B” is the “gray & white” wire, and “C” is the “brown & white” wire. Because of the different suppliers of TPS’s (and the potential for different wire colors), you may need to “poke around” on the wires in order to determine the positive and negative leads. An easy way to take voltage readings is to stick a safety pin through the individual wires, and then make contact with your Volt Meter probes to the safety pins.
To check voltage, THE IGNITION KEY NEEDS TO BE IN THE “ON” POSITION BUT THE ENGINE DOES NOT NEED TO BE RUNNING. With the positive (+) lead from your voltmeter, pierce the “gray & white” wire. With the negative (-) lead from your voltmeter, pierce the “gray and red” wire. The voltmeter should read no less than .98 volts nor more than 1.0 volts. If the voltage is too high, loosen (but do not remove) the two screws holding the TPS to the throttle body, and rotate the unit counter-clockwise, until the voltage is correct. Rotating the unit clockwise will increase the corresponding voltage. When the voltage is correct, retighten the two screws. The only adjustment is the “slop” between the inside diameter of the holes and the outside diameter of the screws, so we are dealing with just a few degrees of rotation.
Usually, the space between the inside diameter of the holes in the plastic TPS body and the outside diameter of the screws will allow a rotation (clockwise or counter clockwise) of three or four degrees in either direction. This is usually enough to get the correct voltage setting. If its not enough, a small rat-tailed file (like the kind that hobby stores sell for working on jewelry) may be used to file a small slot into the holes to achieve additional rotation.
The Ford ECM’s are very “unforgiving” when it comes to ANY engine modifications from stock. The addition of an Accufab throttle body should not have any negative effect on idle speed, off-idle performance (tip-in) or the RPM returning to idle speed (within a second or two) when the throttle is closed.
If on the other hand, modifications to the stock engine may include additional supercharger boost with the use of different supercharger pulleys (particularly noticeable on supercharged 2003-2004 Mustang Cobra’s) or adding a “re-programming” chip or add-on computer module, the standard TPS voltage readings and other drivability issues may be noticeable, and could include an overly fast idle and a resistance of the ECM to “allow” the throttle to close properly, resulting in a delay between removing your foot from the gas pedal and the engine returning to idle.
These are not throttle body problems. The throttle body is a mechanical device with only one moving part. As long as the throttle body slams shut when you close the throttle (key off, engine not running), the throttle body is functioning correctly. Any other problem is associated with the ECM and the feedback it is receiving, either due to the increased boost at idle (more air supply) or the add-on computer chip sending incorrect (or unknown) data to the ECM.
courtacy of John Mihovetz of ACUFAB
b96gtman is offline
Old 01-18-2010, 09:32 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
The procedure described above is for the '96 to '98 EEC-IV systems, on the '99+ EEC-V systems the TPS does not need to be adjusted, and is not adjustable.
from the '03 shop manual...
Idle Speed Control Closed Throttle Determination
One of the fundamental criteria for entering rpm control is an indication of closed throttle. Throttle mode is always calculated to the lowest learned throttle position (TP) voltage seen since engine start.
This lowest learned value is called "ratch," since the software acts like a one-way. reverse latch. The ratch value (voltage) is displayed as the TPREL PID. The ratch value is relearned after every engine start. Ratch will learn the lowest, steady TP voltage seen after the engine starts. In some cases, ratch can learn higher values of TP.
The time to learn the higher values is significantly longer than the time to learn the lower values. The brakes must also be applied to learn the longer values.
All PCM functions are done using this ratch voltage, including idle speed control. The PCM goes into closed throttle mode when the TP voltage is at the ratch (TPREL PID) value.
Increase in TP voltage, normally less than 0.05 volts, will put the PCM in part throttle mode. Throttle mode can be viewed by looking at the TP MODE PID. With the throttle closed, the PID must read C/T (closed throttle). Slightly corrupt values of ratch can prevent the PCM from entering closed throttle mode. An incorrect part throttle indication at idle will prevent entry into closed throttle rpm control, and could result in a high idle.
Ratch can be corrupted by a throttle position sensor or circuit that "drops out" or is noisy, or by loose/worn throttle plates that close tight during a decel and spring back at a normal engine vacuum.
Because the PCM learns and constantly updates the closed throttle value (the "ratch" voltage) there is no need to set the TPS for any exact starting value. Once the ratch value is known the PCM can determine any throttle position because it knows the rotary rate of resistance change of the TPS, and the starting point...
cliffyk is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
Drastang
09-30-2015 03:48 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: High idle 1400rpm in neutral...
