not really used to the auto trans..
what does the 1 and 2 mean on the auto trans? I keep wanting to shift.. but its an auto and not a 5 speed.. so i gotta know what the 1 and 2 mean...
Not quite. If you put it on the 1, it will stay in first till redline, then shift. Second is the same way. I think that it boosts line pressure too.
Thanks
On mine, leaving it in a certain gear only allows you to go to that certain gear, but always starts at "1"
Lets say its in "1", then it will be in 1 and only 1. Will not up****
If its in "2", tranny will start in first gear, then shift to second but not go higher than second. And etc.........
If i'm racing from a dig, then I usually just leave it in drive, because it will shift fine. But from a roll, i put it into "2" because I don't want to have to step on the gas and waste time downshifting once the race has already started.
Just put it in "D" to see how it shifts. If you want to shift it like a manual, then you can start off in "1" shift to "2" at 5200-5500 rpm, then put it in "D". If it has trac control, you will want that off as well.
