Coolant what colour/how to change?
Old 02-20-2010, 12:45 PM
krazymofo22
krazymofo22's Avatar
Default Coolant what colour/how to change?
Hey guys
I have a 2002 Gt and i was wondering how do i change my coolant? Right now i have orange coolant in my car, and i dont think its the right coolant for my car. I would like to change it.
What colour would be the right colour for my year? I saw i tread about it on this forum i belive but i cannot find it .
Thanks in advance
krazymofo22 is offline
Old 02-20-2010, 02:35 PM
DreamerGT
DreamerGT's Avatar
Im sure that is motorcraft coolant, its the right stuff. Are you having any problems?
DreamerGT is offline
Old 02-20-2010, 03:08 PM
krazymofo22
Im not having any problems with it. I want to change the coolant, since ive never done it yet on my car. I bought it in 2007
Old 02-21-2010, 03:42 PM
krazymofo22
bump.
Old 02-21-2010, 03:58 PM
FlamingoGT
FlamingoGT's Avatar
Isn't Dexcool orange also? (which would be a big no-no in our cars)
I don't know about Canada, but down here in the states, dealing with used coolant is about as bad as used oil in regards to the disposal of it. Check with your local parts store and see what they say.
For a quick drain and replace, run the car long enough to warm it up enough for the t-stat to open, open the drain **** on the bottom of the radiator; after it is all drained out, fill with the proper mix of the new stuff. This obviously isn't as good as a flush and fill, but if age of the current coolant is your only concern, this is usually good enough.
FlamingoGT is offline
Old 02-21-2010, 04:05 PM
krazymofo22
If i just do the quick drain and replace, will their still be old coolant in it? Because i dont want to mix different coolants
Old 02-21-2010, 05:57 PM
FlamingoGT
FlamingoGT's Avatar
Yes, there will still be some of the old coolant still in the engine. As long as the coolant that is in there now isn't 'bad' or the wrong kind, it really isn't that big of a deal to do this. But if it is a concern to you, you will have to do a power flush.
A compromise that would get more of the old coolant out using the drain and fill method would be to fill the radiator with straight water and run that for a few minutes, then drain that... and maybe repeat until the water comes out clear... then fill with the proper mix.
Old 02-21-2010, 07:26 PM
krazymofo22
thank you
Old 02-21-2010, 07:31 PM
krazymofo22
i forgot to ask this, would you know or anyone know the amount of coolant needed when its empty?
Old 02-21-2010, 07:56 PM
smashten
smashten's Avatar
18 qts
smashten is offline
Quick Reply: Coolant what colour/how to change?
