Compucar nitrous setup
Old 02-26-2010, 08:04 AM
Warrior1876
Warrior1876's Avatar
Default Compucar nitrous setup
I have a compucar nitrous kit. They do not make a window switch for there kits that i can find. My question is if i buy say an MSD window switch am i going to have a problem because my car is a stick shift. I am guessing its probably going to kick in at 1st gear and i really would prefer it start in second. Also when i left off the gas to shift is that bad for then engine because i am off the gas on a 5 speed. I would not be hitting a button to let off before i shift with a window switch. I didnt know if it was bad to have a switch with a 5 speed. THanks
Warrior1876 is offline
Old 02-26-2010, 09:07 AM
mrtstang
mrtstang's Avatar
Letting off the gas when shifting is a GOOD idea lol. A window switch is ideal for a manual. I have a MSD window switch on mine (it's a 5 speed) and have it set to spray between 3-6k.
mrtstang is offline
Old 02-26-2010, 07:58 PM
97gold
97gold's Avatar
what is a window switch and does it do
97gold is offline
Old 02-26-2010, 08:09 PM
mrtstang
mrtstang's Avatar
It allows the nitrous to only spray between a certain rpm range.
mrtstang is offline
Old 02-26-2010, 08:11 PM
tim2002gt
tim2002gt's Avatar
It sets a certain rpm range that the system can be activated. Therefor it will not spray nitrous under a set rpm and over a set rpm. I have mine set to come on at 3k and shutoff at 6200 rpm.
edit: you beat me to it!
tim2002gt is offline
Old 02-26-2010, 08:16 PM
mrtstang
mrtstang's Avatar
Damn dude lol... 11.5??? That's faster than the last time i saw. Did you do something different in the last several months? I seem to remember you running a 11.7 or 11.9 IIRC.
mrtstang is offline
jwog666
12-27-2021 08:09 PM
fastbackford351
10-01-2015 12:24 PM
guitarman376
09-30-2015 05:54 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: Compucar nitrous setup
