I mean the bearing race in the housing, The inner race is being stubborn!
I just rented a bearing race tool, not sure its helping much yet
It gets confusing as it's the outer race, or "cup", of the bearing that's pressed into the housing as opposed to the bearing's inner race ("cone") on the pinion shaft.
However then there are inner and outer bearing assemblies for the pinion shaft...
Ford has special tools for removing the cups, however there are universal tools for driving them out--here's what Ford's looks like:
Finnally got it out, got a bigger hammer, Tips on installing a new one? I was thinking about sticking them in the freezer? can I use any grease to help?
So I setting up the pinion, I found the old pinion to be 1.896" and the new one is 1.789", So if you subtract the 2, my shim would be .107"!?! Thats a big shim...
you gotta triple check the measurement for both, check the stock pinion with the original shim and check it that way, then put the original shim on the new pinion and see what you get i bet its gunna be dead on if using FRPP gears
