Installing Steeda Bumpsteer Kit
Those directions tell u everything u need to know, and no special tool is required once u get the crown nut off just give that biznatch a nice smack with a mini sledge and it will drop like a prom dress.
And I thought I was the only one who smacked their prom date with a mini sledge!
There's no special tool needed, but there is something to use to save about thirty seconds a side if you have an air compressor. I have a 32mm socket that I cut a big U in the side so I could slip it over the end of the tie rod end stem. Then I used my impact gun to run it in reverse to spin the old tie rod end off. I only used it when the old one was all rusted on and a pain in the *** to get off. Other than that it's pretty straight foward and easy.
The tool is a big hammer. I did this a few weeks ago with no problems. I used the instructions from Steeda. I think I had the spacers just like they showed but it depends on how low your car is. I put the Steeda ball joints on at hte same time and they gave me more problems than the bump steer, but only cause I had to get the ball joint press, then it was easy.
If you don't have the ball joints I recommend doing them at the same time. Your going to want them to fully fix the bumpsteer problem and it sounds like this is your DD so save a few hours and get those on too.
10-01-2015 09:11 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-02-2015 08:40 PM
