Auto Transmission help and a couple other questions.
Old 03-28-2010, 05:26 PM
green2000gt
green2000gt's Avatar
Default Auto Transmission help and a couple other questions.
I have a 2000 automatic gt with almost 40,000 miles on it, I want to get everything up to date so I know where I am at with it. I want to have the transmission flushed with a filter change and have a transmission cooler installed. I am going to get this one http://www.jegs.com/i/B%26amp%3BM/130/70264/10002/-1
that should be a good one right? I also am going to use motorcraft mercon V
That is the fluid I should use correct?
I am not sure if I should have a transmission shop do it or have ford do it, what do you guys think?
if I have the transmission shop do it should I supply the ftranny fluid so I know mercon V was used?
Where should I tell them to mount the cooler?
Next on the list is a radiator flush and a tune up
what all is involved in a tune with these engines? new plugs, wires ect?
green2000gt is offline
Old 03-28-2010, 09:09 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Ok, well first of all if you take it to Ford for the flush it'll be near 180$ (thats what we charge) and they most likely wont install your cooler for you. A trans shop should know which fluid to put in and probably wont have any issues doing the cooler for you as well.
And a "tune up" for your car would be a new fuel filter and new plugs. There are no wires, just COPs.
WhiteFoxGT is offline
Old 03-28-2010, 10:13 PM
green2000gt
Is motorcraft mercon V the best or is like valvoline or a nother brand of mercon v ok to use? what is in mercon v that is different from others?
Old 03-28-2010, 10:19 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
V is what ford recommends. Doesnt really matter what brand of V you put in, however if you have access to motorcraft, get it
Old 03-29-2010, 11:57 AM
green2000gt
bumpp
mtgldr
02-03-2024 09:00 PM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Pyrate Dave
09-10-2015 07:30 PM
vintageaion
09-08-2015 10:45 AM
Gabe_mlcc
09-07-2015 11:56 PM
Quick Reply: Auto Transmission help and a couple other questions.
