Coilovers
Old 04-10-2010, 04:57 PM
Clif Brohn
Clif Brohn's Avatar
Originally Posted by hpwrestler220
What are you trying to achieve?
Jazzer's car will run circles around many cars that auto-x. So will jmac's, just not as many circles haha
I'm curious about this too, what exactly are you looking for performance wise? I have GR40 coilovers/poly bushings/solid LCA's and koni shocks/struts; and it handles fantastically... Jazzer has the front SLA(short arm/long arm) kit from Griggs Racing, thats as good as it gets as far as mustang front suspension is concerned... Good people to take advice from.
Clif Brohn is offline
Old 04-10-2010, 04:58 PM
dimebag
dimebag's Avatar
I am willing to bed that whatever your trying to achieve, there are parts for
dimebag is offline
Old 04-10-2010, 05:22 PM
jmac72187
corner carver
jmac72187's Avatar
Originally Posted by 98BlackCobra
I don't think your typical mustang designed suspension will do what I want to achieve.
I highly doubt you will design a better set up than Griggs, MM, Agent-47, etc.
Do whatever you want, but to do it correctly you are going to have to spend some money and have the car set up correctly.
jmac72187 is offline
Old 04-10-2010, 05:25 PM
jmac72187
corner carver
jmac72187's Avatar
What are you doing, off roading?
The parts available will allow you do pretty much anything.
Old 08-08-2010, 04:23 PM
98BlackCobra
98BlackCobra's Avatar
christ sakes, I want to do my own thing... I want to be super low like my e36 was. My sportlines arent low enough and I want stiff springs and fully adjustable height, I want to tuck on all four tires with a flush fitment. I'm not about racing in any way, I have yet to see a sn95 sit how I want mine to sit. That miata looks SICK bro!
98BlackCobra is offline
Old 08-08-2010, 05:59 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
The fenders of the SN95 are really not cut well for the look I believe you are after
Here is a pic of the ABSOLUTE LOWEST you can go and be streetable:
My front tires rub on larger bumps at OEM diameter and am also running a tube "K" to address the geometry issues created by such a drop. I have about 2.5" of clearance under my ride and the entire underside is beat to crap
Jazzer
Jazzer The Cat is offline
Old 08-08-2010, 08:24 PM
98BlackCobra
I want to roll like this:
I realize the fenders on mine aren't perfect but I can still flatten the lip of the fender and possibly do a small pull. I'm waiting to see what his suspension setup is.
Old 08-09-2010, 08:01 AM
Jazzer The Cat
Retired Moderator
You can't roll like that
Even that guy has serious ride, handling and geometry issues, I can guarantee. Not to mention rubbing. It takes more than just rolling the fenders I can tell you. I have cut the entire lip off the underside of my fenders, there is just no room up underneath for the tire/wheel in which to travel.
Again.... my car is the MAX you will ever go and be streetable.
Jazzer
Old 08-09-2010, 09:05 AM
devongarver
devongarver's Avatar
jazzer has a pretty good run down in his sig of what is done on his car, several pics as well. Check it out. In the mean time, you could consider this?
devongarver is offline
Old 08-09-2010, 07:38 PM
uberstang1
Chupacabra
uberstang1's Avatar
that fox body gives me wood, i got an 87 ranger with a 347 stroker, 9 inch rear, dana 44 , ratchet shifted c4 and dana 20 sittin on 12 inches of lift and 40"boggers, its time to pull of the ranger shell and drop a fox on that frame, whose got one for me. Ill trade a rebuildable procharger head unit for it.
uberstang1 is offline
Quick Reply: Coilovers
