anyone with a vortech??
Old 04-22-2010, 02:12 PM
0949er
0949er's Avatar
Just curious, for any of those who said they had a vortech non-ic, how long has the blower been on your car, how many lbs of boost are you running, and what are your rwhp/rwtq numbers?
0949er is offline
Old 04-22-2010, 04:52 PM
NaughtyGeek
NaughtyGeek's Avatar
Originally Posted by Pony123
I just bought a V2 myself non intercooled.. What PSI you guys recommend on running on a stock fuel pump and injectors?
2006 mustang gt
I wouldn't run ANY boost on the stock injectors and prolly wouldn't go more than 4 PSI on the stock fuel pump. Injectors and fuel upgrades are MANDATORY for a boosted application.
NaughtyGeek is offline
Old 04-22-2010, 05:09 PM
mustang51js
mustang51js's Avatar
ive read of guys putting 50,000 or more miles on them, it depends on your motor and tune. Most basic vortech kits put you between 7-9 psi and roughly 375rwhp.
mustang51js is offline
Old 04-23-2010, 10:32 AM
xmikevankuikenx
xmikevankuikenx's Avatar
I ran non-intercooled for a summer before getting the intercooler. 8lbs
Put the intercooler and pulley on and have been running fine for 2+years still pushing 8lbs. I got it tuned at the same place you did, Pro Dyno.
xmikevankuikenx is offline
Old 04-23-2010, 11:35 AM
Hangwire
Hangwire's Avatar
If you cant afford to buy an intercooler you are nowhere near being able to afford supercharging your car. What happens when you blow your engine because of all the heat? Theres already the risk even with an intercooler. Then youl be on the hook for a new shortblock AND intercooler after youve learned your lesson.
The result you will get is that of much less power than if you were to have spent that money on heads/cams. This is because with heads and cams your engine isnt pulling tons of timing due to heated up air. Most of the gains you NORMALLY would see with an intercooler will be timed down by the engine's computer to prevent knocking/detonation. You need to buy an intercooler otherwise you will not be satisfied at all.
Hangwire is offline
Old 04-23-2010, 11:45 AM
tdcalhoun89
tdcalhoun89's Avatar
buy a dang intercooler, get a better fuel pump (svt focus?), and better injectors... don't half a$$ something like that jez
tdcalhoun89 is offline
Granatelli Sales
03-21-2016 06:16 PM
ctgreddy
09-20-2015 08:35 PM
09-16-2015 07:53 PM
5.0pntydrpr
08-27-2015 10:26 PM
Soldier GT
08-12-2015 03:46 PM
Quick Reply: anyone with a vortech??
