Emergency Brake is on its way out
Mine's always been pretty weak.
Remove the cable from the caliper is easy. Use a flathead screwdriver to take it out of it's mount on the brake, and there's a spring washer holding it in the caliper. Use the same screwdriver to pop out that washer and slide the cable out.
Go look at the cobra brake swap how-to if you really get terribly stuck with it.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
