A hissing sound
Old 05-01-2010, 10:32 PM
00gtbk
00gtbk's Avatar
Default A hissing sound
Ok i notice when i start up my car it does this like hissing sound it comes and goes.. but i think after it has ran a little while it stops.. anyone know what this could be?
00gtbk is offline
Old 05-01-2010, 10:41 PM
JC316
JC316's Avatar
What kind of hiss? Leaky tire hiss, angry cat hiss, or an Alien that is fixing to cocoon you?
Could be a vacuum leak, or the a/c system, or a pulley going bad.
JC316 is offline
Old 05-01-2010, 10:50 PM
00gtbk
00gtbk's Avatar
Its not a tire hissing.. more like an Alien. its pretty loud and noticeable. sounds like its right under my door.. Ah yeah my A/c isnt very good
00gtbk is offline
Old 05-01-2010, 11:01 PM
00gtbk
00gtbk's Avatar
Also would i have anyproblem installing a 75mm throttle body if mines stock?
00gtbk is offline
Old 05-01-2010, 11:06 PM
stangit9090
stangit9090's Avatar
tb install is a cake walk, and check your midpipe.
stangit9090 is offline
Old 05-01-2010, 11:08 PM
-ToXiC-
-ToXiC-'s Avatar
the TB is a bolt on, so no (unless you have the stock air intake, which will still work but will be hard to stretch).. Have you had any exhaust work done to your car?
-ToXiC- is offline
Old 05-01-2010, 11:28 PM
00gtbk
00gtbk's Avatar
Yeah i had full exhuast done not sure about headers yet ill have to check.. and k&n full system. i just notice that when i read on americanmuscle.com on the 75mm tB's it says for heavily modified gts because the stock ones do not flow enough or something like that.
00gtbk is offline
Old 05-01-2010, 11:40 PM
-ToXiC-
-ToXiC-'s Avatar
more than likely the hissing is an exhaust leak. TB's are bolt on.. to get the full impact of a 75mm TB and Plenum you would need other addon's, but those are not nessesary to put it on.
-ToXiC- is offline
Old 05-02-2010, 02:09 AM
JC316
JC316's Avatar
[QUOTE=-ToXiC-;6977618]more than likely the hissing is an exhaust leak.
+1. Not much else it can be in that area.
JC316 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
Quick Reply: A hissing sound
