RPM's won't go down!
Old 05-07-2010, 01:15 AM
  #21
Mustang813
Mustang813's Avatar
Well, I sat down and looked at how exactly it works. It seems this is my problem..
Mustang813 is offline
Old 05-07-2010, 01:19 AM
  #22
Mustang813
Mustang813's Avatar
Normally I stick with Ford products, but would it make that much of a difference to buy it from an after-market dealer? Fords price is gonna be like $125+, aftermarket, I found for $65.
Old 05-07-2010, 01:25 AM
  #23
Sxynerd
Sxynerd's Avatar
There must be an echo in here?
Sxynerd is offline
Old 05-08-2010, 12:32 PM
  #24
Mustang813
Mustang813's Avatar
Well, I bought a new one and got it today. I put it on, along with the new gasket. It is still doing it.
RPMs are sticking at any amount 2K+, even when I downshift, or go into neutral. I have to press the break for them to go down, and even then they barley go down. In order to stop this from happening, I have to turn my car off, and start it back up. However, it will do it again in about 5 minutes time. Any other ideas...?
Old 05-10-2010, 12:44 PM
  #25
96mustanglx
96mustanglx's Avatar
I'm having the same problem with my 4v. The iac was just changed and it wasn't the problem. My rpm raise when I push the clutch in. Could it possibly be a vaccum hose?
96mustanglx is offline
Old 05-11-2010, 08:02 AM
  #26
devongarver
devongarver's Avatar
Well again, it wouldn't be the IAC, as cleaning it didn't help, and Normally, the IAC will cause it to stall-as in drop the rpms-not raise them up. The only other thing I could think of would be the Throttle Position Sensor...
I see you did try the IAC, and it didnt work..Are you resetting the KAM by disconnecting the battery for 10-15 minutes after the install?
devongarver is offline
Old 05-11-2010, 08:20 AM
  #27
96mustanglx
Yeah I disconnected the battery for about an hour or so and on my way to work this morning it did the same thing. So you think I should try a tps?
Old 05-11-2010, 08:44 AM
  #28
devongarver
Well, honestly, I think that it could be the TPS. BUT, you should PM CliffyK and ask him before you decide. He may be a bit more knowledgeable than I.
Old 05-11-2010, 08:48 AM
  #29
96mustanglx
Yeah I have asked a few of my buddys around where I live and they said it could be the TPS so I will check it out. I will also pm cliffyk and see what he says
Old 05-11-2010, 10:05 AM
  #30
Mustang813
Mustang813's Avatar
I changed the TPS some months ago already.
Quick Reply: RPM's won't go down!
