Problem after installing gear :(
Old 05-11-2010, 12:51 AM
MaKaVeLi
MaKaVeLi's Avatar
Originally Posted by jjandascog
A tuner should correct the speedometer. One thing to check is the dia of the rear tires, are they the same as stock?
yes they are stock
MaKaVeLi is offline
Old 05-11-2010, 06:00 AM
mustang51js
mustang51js's Avatar
Originally Posted by MaKaVeLi
yes they are stock
do you have any other chip or anything that you put on, the tuner should take care of it,sounds like it is not saving.When i had my gears changed i was off by 12mph, got a tuner and that fixed it.I then got a vortech and had to use the chip they gave me for a while and that chip over ride everything on the tuner.I think its something with your tuner and saving your setting, and if you put a lower gear in there its going to sho faster, maybe try 3.90 if it wont save the 3.73 and you should be close, one other thing is the rim size, check that to make sure its on the right setting.
mustang51js is offline
Old 05-11-2010, 05:28 PM
MaKaVeLi
MaKaVeLi's Avatar
i dont have chips, i tried the 3.26 and 3.73 and both of them are the same result
MaKaVeLi is offline
Old 05-11-2010, 07:57 PM
JerseyTrueBlue
JerseyTrueBlue's Avatar
Sounds like it could be an issue with the tuner man, where did you get it from? A buddy of mine had a similar problem with his predator, he sent it back to summit and they sent him a brand new one free of charge.
JerseyTrueBlue is offline
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
5.0pntydrpr
08-27-2015 10:26 PM
jjwinel78
08-17-2015 03:34 PM
Quick Reply: Problem after installing gear :(
