Fuel system from legal performance
I bought a new fuel system with a regulator, new lines, new hat, and dual supercar fuel pumps. I want to know if i can install this now even though i dont need it yet. Will the regulator make it so i would be ok and adjustable?
Are you converting to a return style system?
If you are staying returnless you can install the pumps and run the car. You can't run WOT under 1/2 or 1/4 tank of fuel with the stock tank. You either need an 03/04 cobra tank or install some sort of baffle in your stock tank to run below 1/2-1/4 tank of fuel.
Also with those pumps you need an upgraded FPDM.
No, i currently have the stock system on there but i purchased a return style and want to know if i can install it now. It has dual pumps and i didnt know if i can just adjust the regulator because i am not sure. I have a procharger but only at 8 psi because i didnt forge the engine yet. I am saving for that. I was just wondering if i could have the fuel system installed now.
I think dual supercar pumps will handle a lot of power even if you keep your stock returnless system. Again, to do this you need an upgraded FPDM. I would think about this unless you're planning on huge numbers.
But if you are converting to return style I also think you need tuning changes.
