best shift point?
Old 06-06-2010, 03:29 PM
ctgreddy
ctgreddy's Avatar
Default best shift point?
my buddies got a bolt on 2v, and at the track he shifts at 6k, but says that sometimes it bogs into second. and he was thinking if he could rev it a little higher that it may not do it, but his rev limiter is also at 6k so he can't rev any higher. is this a good shift point or should he bring his limiter up some?
ctgreddy is offline
Old 06-06-2010, 04:00 PM
tim2002gt
tim2002gt's Avatar
A bolt on 2v is not making power that high. He would be better off to shift at a lower rpm. I vary my shift points depending on what gear I'm in. 1st-2nd I try to shift ~6k, 2nd-3rd ~5800, and I try to shift into 4th ~5600. I've had my best ET and mph results shifting this way.
tim2002gt is offline
Old 06-06-2010, 04:05 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
He needs gears if he is shifting at redline and bogging in the next gear... 4.10s or go home
WhiteFoxGT is offline
Old 06-06-2010, 04:38 PM
tbirdscwd
tbirdscwd's Avatar
Yes
And more yes
tbirdscwd is offline
Old 06-06-2010, 08:38 PM
ctgreddy
ctgreddy's Avatar
he's got 3.73's in it. he says it's bogging but it doesn't look it. he pulled off a 12.9@107 with just radials and some little weight reduction so it's gotta be running pretty good.
ctgreddy is offline
Old 06-06-2010, 08:42 PM
TCStangerv6
TCStangerv6's Avatar
I have 3.73's. The reason i don't go with the 4.10's is because i plan on going with some type of f/i later on down the road.
TCStangerv6 is offline
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Quick Reply: best shift point?
