Before timing cams...
Old 08-09-2010, 06:59 AM
97stanger
97stanger's Avatar
Default Before timing cams...
While the heads are still off the car, should I find TDC of the black before putting the heads on and timing the cams? Or will I be fine putting the heads on first and doing all timing steps after the heads are on?
97stanger is offline
Old 08-09-2010, 08:48 AM
devongarver
devongarver's Avatar
This may help...
devongarver is offline
Old 08-09-2010, 11:25 AM
dimebag
dimebag's Avatar
U can do it either way....i prefer to always work with #1 on tdc unless the cam doesnt allow it... on these mod motors there are "safe spots".....piont the crank keyway straight up and then bolt down the cams....
dimebag is offline
Old 08-09-2010, 02:26 PM
nickmckinney
nickmckinney's Avatar
Definitely do TDC with the heads off on a 2V if you are degreeing the cams in.
nickmckinney is offline
mungodrums
10-07-2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
09-28-2015 09:18 PM
StalkerGT
09-25-2015 02:41 PM
09-08-2015 11:50 AM
Quick Reply: Before timing cams...
