car trouble, possible transmission issue?
Old 08-27-2010, 06:43 AM
bruthru2003
bruthru2003's Avatar
Default car trouble, possible transmission issue?
Ive been having an issue with he car over the past few weeks. It started with a low vibration above 60 mph with you let off the gas and both on and off the gas at 70+. Now the car randomly stalls out when I come to a stop while braking. If I do this with the car in neutral, everything is fine. If the car doesn't stall out, the rpms still just randomly between 1200 and 300. While you are slowing down, just coasting without the brakes depressed, it almost feels like the brakes are being applied, the car slows down very abruptly. Any thoughts?
Also on a side note, the car shapes a little more then usual while driving around and has a bit of a wobble when you slow down between 30 to 5 mph. Ive replaced all the brake components recently, had the tires balanced and checked for bulges but everything there looks good.
Any help would be greatly appreciated. FYI the car is an automatic. Thanks in advance.
bruthru2003 is offline
Old 08-27-2010, 09:35 AM
devongarver
devongarver's Avatar
How many miles on the tranny? Factory torque converter?
devongarver is offline
Old 08-28-2010, 07:07 AM
bruthru2003
tranny has 85k miles on it and it is the factory t/c
djbigskrilla
09-20-2022 01:04 AM
msavoia23
12
07-07-2018 12:08 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: car trouble, possible transmission issue?
