Patriot Stage II's
Old 09-09-2010, 10:14 AM
Soldier GT
Soldier GT's Avatar
Default Patriot Stage II's
Hey guys need a little more advice/reccommendations..I'm really leaning towards installing Patriot Stage II heads on my car when I buy my MMR block next summer. I was wondering would those heads be a good fit with my cams (comp stage 1) and my Vortech S/C (V1 T-Trim)? I was also wondering with a good tune would it be possible to hit 500 RWHP with that setup?? Thanks guys!
Soldier GT is offline
Old 09-09-2010, 11:09 AM
MU71L4710N
MU71L4710N's Avatar
you really need to get blower cams to try to get the power your after. stage 1 na's are not gonna hack it with your HP goals. best to spend the money now before the heads and timing chains are put on the motor then have to pay to have it torn down and rebuilt again.
MU71L4710N is offline
Old 09-09-2010, 11:13 AM
uberstang1
Chupacabra
uberstang1's Avatar
Soldier I would go with the new trick flow 2v heads hands down over the patriot set.
uberstang1 is offline
Old 09-09-2010, 11:15 AM
school boy
school boy's Avatar
those heads, even being stage 2s, the ports are a tad too big NA engines. but you being f/i, they may be fine. the 500 mark would be no problem with the setup mentioned. you could have your pi heads ported. ive seen better numbers out of ported pi heads than the patriot stage 2s. either will hit your mark, its your call on which way to go
school boy is offline
Old 09-09-2010, 11:22 AM
school boy
school boy's Avatar
btw, every time ive seen 278 comp cams mixed with f/i, ive seen great numbers. might think about changing to them or blower cams
Old 09-09-2010, 11:28 AM
Soldier GT
Soldier GT's Avatar
Yeah I was kinda thinking the same thing. Just ****'s me off when I have to redo a mod. Wish I could afford the cams now since the car is going to be at the shop tomorrow. What cams would you reccommend??
Old 09-09-2010, 11:32 AM
Soldier GT
Soldier GT's Avatar
hey thanks bro. since I just changed out my cams two years ago will I have to buy any additional hardware or can I just use my setup minus my cams ?? Also bro I see that you are looking for a Mach 1 shaker hood and shaker system. There's a guy on corral.net selling one pretty cheap..
Old 09-09-2010, 12:19 PM
school boy
school boy's Avatar
going to a higher lift cam, you'll have to use valve springs that can handle that much lift. i suggest, if you can afford it, using all new components when building the heads. i have a set of pi heads ported for f/i with crower stage 2 blower cams, crane cams valve springs designed for boost and titanium retainers waiting to go on a built short block. the rest of the head components will be new factory ford pieces. be about a year before i start on a short block, i kinda jumped the gun. do you have a link to that hood, couldnt find it
Old 09-09-2010, 12:33 PM
oxfordgt
oxfordgt's Avatar
I have a set of patriot stage 3 heads that I'm selling for $1000 shipped. Perfect condition.
oxfordgt is offline
Old 09-09-2010, 01:03 PM
school boy
school boy's Avatar
soldier, thats a good deal. ox, is the main difference between the stage 2s and 3s is the valve size?
Quick Reply: Patriot Stage II's
