Wiring Problem Advice needed
Old 09-25-2010, 07:30 PM
4.698GT
4.698GT's Avatar
Default Wiring Problem Advice needed
I removed and reinstalled my D/S door to place the door pins and bushings. I removed the door wiring harness and reinstalled the harness. After hooking everything back up, the unlock/lock does not work on either door, the radio does not work, no power mirrors. If I use the lock button switch the tail lamp circuit is activated somehow. Does anyone have any advice.
4.698GT is offline
Old 09-25-2010, 07:35 PM
MU71L4710N
MU71L4710N's Avatar
obviously its either blown fuses, or something wrong with what you did. so check the fuses then check your work.
MU71L4710N is offline
Old 09-26-2010, 10:28 PM
EI-03-GT
EI-03-GT's Avatar
without looking at a wiring diagram i cant say for sure but i would say you put to wires together and shorted them out blowing the a fuse while somehow putting the tail lamp circuit in the door. just my guess.
EI-03-GT is offline
Old 07-16-2015, 03:29 AM
crabbycobra
crabbycobra's Avatar
Sorry to necro an old thread but... has anybody else had this problem? I've been working on a solution to this for some time, but not coming up with anything.
crabbycobra is offline
bigdaddy51200
08-19-2015 05:09 AM
mweiland
08-16-2015 10:59 AM
defarmer
08-13-2015 06:40 AM
Pain.
08-07-2015 10:48 PM
Quick Reply: Wiring Problem Advice needed
