Trans hesitation
Old 10-07-2010, 03:14 PM
Warrior1876
Warrior1876's Avatar
Default Trans hesitation
Let me first start off by saying that i had a conversion done a few years ago on my 01 GT from auto to stick. When i get on the gas and switch to 3rd it seems to be hesitating a second or two before kicking into that gear. Does anyone know why this would be. I am not sure if i have a t45 or a tr3650 trans because of the swap. I was told it was a year 2000 trans. The Clutch is a centerforce dual friction about a year old. Thanks
Warrior1876 is offline
Old 10-07-2010, 03:49 PM
JC316
JC316's Avatar
More than likely it's a weakening synchronizer.
JC316 is offline
cliffyk
TECH SAVANT
cliffyk's Avatar
Coming from a 2000 it's a T-45, what you describe sound as though the clutch is slipping--how must free play is in the pedal?
It should be 1 to 1-1/4" when you press on it with your hand, before you feel the TOB start to load the clutch spring...
cliffyk is offline
Old 10-07-2010, 04:05 PM
Warrior1876
What is a weakening synchronizer and what does it take to fix it. Will it be an expensive repair.
Old 10-07-2010, 04:09 PM
Warrior1876
This was going on even with my old clutch. I never had it looked at and am having my engine put in soon so want to make sure eveything is up to par. I also have a custom hydraulic clutch setup. I had this put in because of the hard pedal pressure. I first put in the dual friction clutch because i was told that would fix the issue but it was still to hard so had them do the hydraulic setup which did help quite a bit. I never understood why the pedal was so hard because my brother had the same clutch and it was much lighter.
Old 10-07-2010, 07:45 PM
Warrior1876
Is the tr3650 that much better than the T45? How do they compare?
Thunderball
15
11-22-2015 11:49 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: Trans hesitation
