Operating voltage range of the fuel pump?
Old 01-22-2011, 12:38 PM
0949er
0949er's Avatar
Default Operating voltage range of the fuel pump?
Anybody know the voltage range of the stock fuel pump?
0949er is offline
Old 01-22-2011, 01:38 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Well the pump is a variable voltage design... so the FPDM gets B+ and sends voltage to the pump as necessary. What exactly are you trying to figure out?
WhiteFoxGT is offline
Old 01-22-2011, 03:01 PM
0949er
0949er's Avatar
well, does that mean its running at 10 V at idle and 12 V at full throttle? (just guessing numbers, but is that what you are saying?) and if so, what is the actual range between idle and full throttle in volts?
I am trying to figure out if this company fudged its LPH #'s on its flow chart (by over-increasing the test voltage that a stock GT will not run)
0949er is offline
Old 01-22-2011, 03:24 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
I dont have the exact voltage numbers handy, but it wont run more voltage then the car is putting out... so its safe to say that the pump doesnt see higher than battery voltage while running, so its going to be 13.5-14.5 volts
Old 02-10-2011, 06:41 PM
tbirdscwd
tbirdscwd's Avatar
Like whitefox stated, the pump is controlled by the PCM via the FPDM. You won't ever get over the max voltage output from the alternator, but most likely will get less than that even at full throttle. The initial voltage when priming is up in the high 10 to mid 11 volt range. I would have to assume that max voltage would be somewhere in that neighborhood, but I can look it up in the morning for sure.
tbirdscwd is offline
Old 02-11-2011, 10:02 AM
Hangwire
Hangwire's Avatar
Kenne Bell BAPs can increase fuel pump voltage to 17+ volts under boost.
Hangwire is offline
jwog666
12-27-2021 08:09 PM
svfetter
10-05-2015 11:39 AM
Matt's 95 Stang
10-05-2015 07:16 AM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Operating voltage range of the fuel pump?
