What Shocks/Struts/Springs setup
Old 03-03-2011, 10:05 PM
EaZy DuZ iT
EaZy DuZ iT's Avatar
^like i said 250 is for the install. Dont have the tools to do the install.
500 is for the shocks/struts and springs. I dont see how 500 isnt enough for a decent setup.
EaZy DuZ iT is offline
Old 03-03-2011, 11:47 PM
hpwrestler220
hpwrestler220's Avatar
You might need $14 worth of tools...
A 12mm wrench, a 15mm wrench, and maybe one other one. A socket wrench and a couple attachments would help as well...
But anyway, the bullitt kit would be the best budget setup. Increased handling while still being fine for daily
hpwrestler220 is offline
Old 03-04-2011, 01:20 AM
EaZy DuZ iT
^ would it be a better choice over the high performance tokicos?
Old 03-04-2011, 01:13 PM
jtb727
jtb727's Avatar
http://www.cruizinconceptswholesale....ts.asp?cat=158
Same kit for quite a bit less, and just for reference here is another thread about the same kit, with opinions from people who have used tokico.. It's the same Kit I'm going to be gettin in a month or two.. Sounds like its worth the $ for sure...
https://mustangforums.com/forum/4-6l...nsion-kit.html
Theres the link so you can see what people are sayin about it..
jtb727 is offline
Old 03-04-2011, 02:23 PM
02TrueBlueGT
02TrueBlueGT's Avatar
Not trying to be smartass, but I would say go to Sears, get the $200 socket setup from Craftsman, and that'll help you do projects in the long run as well. I'm not the greatest with some of this stuff and was able to do it.
02TrueBlueGT is offline
Old 03-04-2011, 03:07 PM
sonicx
speed'n
sonicx's Avatar
Originally Posted by HasABetterSN
Also, with that budget, I would consider doing the Bullitt suspension package, you can pick one up at the dealership for $440 or so. Includes a 1" drop, Tokico shocks/struts, and front/rear sways. Great bang for the buck
I fully back this
sonicx is offline
Old 03-04-2011, 04:31 PM
hpwrestler220
The high performance dampers such as the tokico D-specs? Is that what you are referring to? Or the illumina's?
The tokico HP shocks/struts are basically the same thing as the bullitt/mach 1 stock dampers. But i have heard that the HP's are valved a little bit better than the stockers on the machs/bullitts...
The tokico d-specs are fully adjustable and are more of an intermediate track setup damper or an aggressive daily setup.
The illuminas are adjustable i believe, but they are drag oriented.
If you are looking for max performance, go with bilstein HD's or koni yellows. If you are looking for a damper that is better than stock, yet still rides great, go with that whole tokico kit wiht the HP's and the springs that come with it. Or get some springs like eibach or H&R SS and get those Koni str's or w/e they are called. I hear those things are awesome for the price
jwog666
12-27-2021 08:09 PM
fastbackford351
10-01-2015 12:24 PM
guitarman376
09-30-2015 05:54 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: What Shocks/Struts/Springs setup
