Question about Gearing. 98 GT
Old 05-28-2011, 08:00 PM
Daniel98GT
Daniel98GT's Avatar
Default Question about Gearing. 98 GT
I just recently bought a 98 gt. Its my first mustang and also my first rwd car. Im pretty sure the rearend gearing isnt oem. My second gear only goes to about 50ish mph at 6k rpm. What gear set could this be? 4.10, 3.73? Like i said i dont know to much about rwd's. Any help is appreciated. Thank you.
Daniel98GT is offline
Old 05-28-2011, 08:31 PM
Soldier GT
Soldier GT's Avatar
410's my man..
Soldier GT is offline
Old 05-28-2011, 08:40 PM
Daniel98GT
Daniel98GT's Avatar
Originally Posted by Soldier GT
410's my man..
Thank you very much sir. It much much stronger than a stock GT.
Old 05-28-2011, 08:44 PM
Soldier GT
Soldier GT's Avatar
You will see a difference. By far the best bang for the buck under 500 dollars!
Old 05-28-2011, 08:58 PM
7gtthrilla
7gtthrilla's Avatar
4.10's are definitely the way to go. They able you to get off the line quicker meaning more shifting and less top end or top speed, but is definitely the best mod to make. The 3.73's give you more top speed but do not allow you to get off the line quick. I say 4.10's.
7gtthrilla is offline
Old 05-28-2011, 10:43 PM
jeh4269
jeh4269's Avatar
I have a 98gt as well.My second gear is about identical to yours.I'm pretty sure mine is a stock gear which I believe is a 3:08 but I am not 100% sure on that.Mine actually does 55 at around 5700 rpm.I bought my car stock except for the flowmasters and the guy I bought it off of didn't say that the gears were changed.
jeh4269 is offline
Old 05-28-2011, 10:48 PM
Daniel98GT
Daniel98GT's Avatar
I actually just came back in from driving it and i tested second gear to 6k rpm and its right at 50 mph. I can putt around in 4th gear at 20mph all day. But thanks for all the help guys. I really appreciate it.
Old 05-29-2011, 03:45 AM
Demonhead
Demonhead's Avatar
Do 410s give you about 40-45mph on 4th gear 2k rpm? I'm trying to see what gears I have since I bought my car used also. I can also do 45 on 5th gear doing about 1.5k
Demonhead is offline
Old 05-29-2011, 05:48 AM
99GTvert
is my username.
99GTvert's Avatar
To find out for sure, you can jack up the rear of the car and count the rotations of the driveshaft with one complete turn of the rear wheel. This would require putting the jack stands on the differential assembly unit (tube, not pumpkin...though that might work OK I don't know) with one stand on each side.
99GTvert is offline
Old 05-29-2011, 07:55 AM
Daniel98GT
Daniel98GT's Avatar
How many turns of the driveshaft should i get with one full rotation of the tires if i have 4.10's?
Quick Reply: Question about Gearing. 98 GT
