need a little help with replacing rear main seal
Old 08-10-2011, 10:03 PM
rayt24
rayt24's Avatar
Question need a little help with replacing rear main seal
i am goimg to replace the clutch on my 98 gt but the rear main seal seems to be leakin a little bit iam just wondering how involved it is to replace it. just want to know what iam getting in to.
rayt24 is offline
Old 08-11-2011, 05:23 AM
uberstang1
Chupacabra
uberstang1's Avatar
you simply remove the flywheel and u can ubolt the "rear main seal plate", a couple 10mm bolts hold it in if I remember correctly, then pry the old seal out of the plate, MMR sells a whole new plate that comes with double seals it might be worth looking into since you are gonna have it apart.
uberstang1 is offline
Old 08-11-2011, 07:52 AM
amoosenamedhank
amoosenamedhank's Avatar
Just make sure when you're sliding the new seal on that everything sits on the crank flush. The first time I did the real main, the inside lip of the seal got folded over and I didn't notice it. Man did that thing leak like crazy.
amoosenamedhank is offline
Old 08-11-2011, 09:15 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Felpro's seals come with a plastic guide sleeve that makes installation a snap...
cliffyk is offline
Urambo Tauro
09-07-2015 12:47 PM
jesse1125
AmericanMuscle.com
08-26-2015 02:34 PM
Nexuia
08-23-2015 11:30 PM
Hogquad
08-23-2015 05:26 AM
Black_GT_02
08-20-2015 01:26 PM
Quick Reply: need a little help with replacing rear main seal
