reverse grinds
reverse grinds
iv searched this and alot of people have the problem but no real answer, whenever i get into the car and shift into reverse it grinds pretty hard. turns heads in a wrong way lol
any answers?
any answers?
My car does it too, do you have a t5 tranny? there is no synchro so it couldnt be that, some people say its the reverse idler gear. but have you tried putting it in 4th or 5th first then put it in reverse and trying it?
thats exactly what iv heard, i just picked the car up a week ago and trying to feel her out. i dont think its a big deal but the noise is kind upsets me because its only sometimes, at first i toulght it was because i was on a slight hill but nope. i needa try the 5th first then R and see where that put me
If 5th to reverse doesn't work go from 1st to reverse. It will work about every 3rd time. Sometimes you have to let the clutch out in neutral and start over again. Welcome to the world of the T45.....enjoy.
I think so......not really sure, I have a 98 with (obviously) the T45. However, unless the OP has his trans swapped for a 3650, he's feeling the woes of the T45 :P
BTW I'm not bashing your comment Demonhead.
I found when mine was doing this before I got it rebuilt. If I remember correctly (it was by habit). I would shift into 4th gear lift the clutch just enough to put load (dont let it it out to much) and then push the clutch back in (this is in order to slow the syncros). then one full and smooth motion from forth up and over and down. It would go in everytime.
That or sometimes the gearing didnt seem to line up and if you release
your emergency brake before you try to put in gear, it will roll an inch so the gears line up.
thanks guys, ya i guess imma have to find her sweet spot. the first time it happen i was like.... uh wtfrench toast. car is in the shop right now being repainted , when i get her back ill update and see if iv figured her out yet
