5th gen axle assembly swap to a 99 gt
Look for a differential specialty shop, i got mine done there with a cobra differential clutch pack and spring , paid like 200 labor if i remember correctly, this was a few years ago and the differential is still holding up perfectly.
http://www.americanmuscle.com/ford-88-traclok-kit.html
pretty sure thats the kit in have in mine and its great.
they will do the gears (if you want gears) at the same time for probably no additional labor cost since they have to remove them for either job.
BUT, you said your differential is actually falling apart? like,. its broken into pieces? this may be a bigger issue than we are thinking... what happened exactly?
I don't know exactly what happened, but we got the car up in the air and when you spin the right wheel, it makes a clicking noise as it goes around. And if you spin the right wheel nothing even happens. If it was working correctly the other wheel is supposed to spin in the opposite direction right? The left wheel actually gets stuck and wont move unless you yank on it.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
09-10-2015 08:39 PM
