tire sizes??
Old 12-31-2011, 06:33 PM
EddyG
EddyG's Avatar
Default tire sizes??
ok i am going to buy some 03 chrome cobra rims for my 98GT. i was thinking can i put 265 in the front and 275 in the back of a 17x9 front and back or will a 275 not fit on a 17x9 rim. I really dont want to get staggered because im only 17 and dont want to buy tires more often than i need to
EddyG is offline
Old 12-31-2011, 11:50 PM
02GTman
02GTman's Avatar
A 275 will fit on a 17x9 wheel. You say you don't want the staggered wheels because of having to buy tires more often. With the set up your talking about 265 front, 275 rear you wouldn't be able to rotate them any way.
02GTman is offline
Old 01-01-2012, 01:04 AM
EddyG
EddyG's Avatar
Wow I look stupid haha I meant 275 front and back could the 275s fit in the front without trouble??
EddyG is offline
Old 01-01-2012, 01:51 AM
02GTman
02GTman's Avatar
I'm not sure if 275's will work on the front of the SN95's. I'm sure someone will chime in that can say for sure.
02GTman is offline
Old 01-01-2012, 12:52 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
A 275 will typically rub up front on an SN95, but think a bit less likely on a New Edge.
This is really a bit large a tire for a 9" wheel, IMO, and better off with a 265< for better turn-in response and less sloppy in the corners.
Jazzer
Jazzer The Cat is offline
Old 01-01-2012, 10:14 PM
trailor
trailor's Avatar
Jazzer, I know you are very knowledgeable and are a trusted source for wheel/tire/brake/suspension info, but 275/40/17 tires are actually recommended for 9 inch wide rims according to tire rack. not only that, but they are also (almost exactly) the same height as the stock recommended tires, 245/45/17, thus will require no speedometer recalibration. as to fitting up front, my friend runs em up front on his 97 cobra, not sure about his rub issues, but he gets around town fine.
trailor is offline
Old 01-02-2012, 07:58 AM
Jazzer The Cat
Retired Moderator
I didn't say they don't work, silly... Just said my opinion
They tend to rub on the SN95 chassis, but not usually very bad. My bigger issue is the "looser" cornering they provide, over a narrower tire. When pushed harder in a corner, they will roll-over up onto the sides more and one looses his/her grip.
If one is not into cornering and can address/live with a bit of rubbing, a 275 will work fine .
Jazzer
Old 01-02-2012, 09:16 AM
uberstang1
Chupacabra
uberstang1's Avatar
Talking
Jazzer
Watcha talking about Jazzer, I'm gonna run a 15x3.5 wheel with a 165/80/15 in the twisties, how you think I'll do????
uberstang1 is offline
Old 01-02-2012, 09:43 AM
Mustang_NTriangle
Mustang_NTriangle's Avatar
OP just run 265s at all 4 corners.
Mustang_NTriangle is offline
Old 01-02-2012, 12:52 PM
Jazzer The Cat
Retired Moderator
Dood.... 315's baby
2007CalSpec
09-09-2015 05:37 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
M3hunter
09-05-2015 03:42 PM
Quick Reply: tire sizes??
