Disconnecting upper fuel lines
Old 01-09-2012, 01:28 PM
Chris98Gt
Chris98Gt's Avatar
Yea, I've never actually saw a 98 with a returnless fuel setup. Mine was a return setup, but the tank and lines were similar to a returnless system because it had a return style pump in a hat assembly in the center of the tank. As for disconnecting the lines, idk I've never took them loose there before.
Chris98Gt is offline
Old 01-09-2012, 01:54 PM
uberstang1
Chupacabra
uberstang1's Avatar
Thats interesting i was pretty sure all the 98s were returnless didn't know it was a split year.
uberstang1 is offline
Old 01-09-2012, 03:08 PM
BraMas
BraMas's Avatar
Here are some pics
This is what the clip looks like
And for the other I like to use needle nose pliers. The Bent kind seem to work best but I'm sure normal ones work also
Squeeze the tabs together and push the clip down and out of the tabs
Pull the line off and take the white clip off the metal fuel line
Put it back in the rubber fuel line. It must go all the way down in the pic. it still needs to lock into the tabs
When re installing the fule line with the round clip will just click back on providing you put it back on the rubber line correctly.
The pull clip you put the rubber line on the metal one and slip the clip back into the hose. You will probably have to more the rubber line up and down slightly to get it to go all the way in
BraMas is offline
Old 01-09-2012, 06:58 PM
1998Slow 'Stang
1998Slow 'Stang's Avatar
Holy information, BraMas! That was one hell of a detailed writeup for what I needed. I really appreciate that! As for your instructions on putting it back together, they are irrelevant lol. I'm going to clamp fuel injector hose to the metal lines and run them to mark Viii lines for my swap that is in progress. Thanks for the all the help!
1998Slow 'Stang is offline
Old 01-10-2012, 08:15 AM
BraMas
BraMas's Avatar
I figured it was more info than you needed but I kinda did it for people in the future
BraMas is offline
Old 01-10-2012, 11:29 AM
1998Slow 'Stang
Much appreciated.
SteelerNation82
09-16-2015 07:11 AM
TfcCDR
09-14-2015 12:08 PM
tramphardrocker
09-13-2015 08:56 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Disconnecting upper fuel lines
