ABS light on
Old 02-14-2012, 11:43 PM
SXGT
SXGT's Avatar
Default ABS light on
I dont even know where to start. is there a fuse for this?
SXGT is offline
Old 02-15-2012, 12:01 AM
Fink
Fink's Avatar
check your brake fluid, if its too low, the abs light comes on.
if thats not the case, one of your sensors is pooched.
Fink is offline
Old 02-15-2012, 12:37 AM
SXGT
SXGT's Avatar
fluid level is fine.
SXGT is offline
Old 02-15-2012, 05:53 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
There can be several reasons that the ABS light is on.
You have 2 fuses, so check them both. A 25 amp one, under the hood and a second one, of like 5 amp or something, under the dash.
If you have a different diameter tire at ANY, but not all corners, this can trigger the light as well.
Jazzer
Jazzer The Cat is offline
Old 05-06-2012, 05:24 PM
SXGT
SXGT's Avatar
i have 215, 55s so yeah how do I reset the thing.
SXGT is offline
Old 05-08-2012, 07:22 PM
SXGT
SXGT's Avatar
fuses checked out OK. is there a meter that will read codes like a check engine light meter? i see the thing that says ABS system test next to my fuse box under the hood
SXGT is offline
Old 05-11-2012, 01:41 PM
SXGT
SXGT's Avatar
can I try to clean my sensors?
SXGT is offline
Old 05-11-2012, 08:58 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The codes can be read through the OBD2 port, with a reader capable of reading them of course. However most inexpensive ones (<$150) cannot as the ABS, GEM and airbag modules communicate over the ISO 9141-2 K line on pin 7 of the OBD2 port.
The PCM uses J-1850 PWM protocol through pins 2 and 10, this the only port most codes will read on our cars...
cliffyk is offline
Old 05-12-2012, 01:44 AM
mustangman02232
mustangman02232's Avatar
pretty sure the parking brake comes on with low fluid? ABS is probably a sensor, or put a piece of electrical tape over it
mustangman02232 is offline
Old 05-12-2012, 06:35 PM
ESABATM
ESABATM's Avatar
Pull the bulb
ESABATM is offline
Quick Reply: ABS light on
